Advance 5051 Quick Menu button no response
  • KL568
    _
    • Feb 2011
    • 324
    [Misc] Advance 5051 Quick Menu button no response
    Hi, all
    Have anybody came across Quick Menu button when press, there is no response ? Access from RUI, also unable to see the web link for Quick Menu as compare another unit of 5051 which have it.
    The relevant service mode is set as 1; firmware is v64
    Had upgrade firmware to v69 but still NG. Set Service Mode for Quick Menu to 0 and reboot; set it back as 1 & reboot, also a dead end.
    Thank you in advance for any leads provided
  • zoraldinho
    teacher-guide-expert-guru
    • Mar 2008
    • 5007
    Re: Advance 5051 Quick Menu button no response
    try with self diagnostic test?
    • KL568
      _
      • Feb 2011
      • 324
      Machine full features works including access via CDS firmware update, only that Quick Menu don't work.
      Had ask around my local support, facing similar issue. Their only few solutions is Format HDD / Replace HDD / Initialize All Data ( which I try and 20 minutes later, Quick Menu button came back normal) but this last solution has been tried by my local support, problem came few months later.
      • zoraldinho
        • Mar 2008
        • 5007
        Good to know.Swap the disc with the same model to be shore.
        • KL568
          _
          • Feb 2011
          • 324
          Yes, only those 3 seems to solve the problem & return Quick Menu button to normal.
          Was thinking, any of you guys' might have came across this issue and have a better solutions than mine's, which wasted time or parts replace of perfectly working HDD.
