Canon clc 3220, screen goes blank just as it starts to feed a sheet
  • matrixgav
    • Aug 2025
    Hi Guys,
    My 3220 has just started this problem, just as it starts to feed a sheet either from drawer1 or s/bypass, the machine almost shuts down,
    i get a blank screen and the normal beep like there is a jam or something. There is no error message but the machine is still on.
    Any ideas??
  • teckat
    • 16083
    Re: Canon clc 3220, screen goes blank just as it starts to feed a sheet
    Originally posted by matrixgav
    Hi Guys,
    Any ideas??
    power off/open back of printer
    remove Memory (all) clean ends & re-seat
    • matrixgav
      Thank you very much, it worked straight away
      • teckat
        • 16083
        COLOR HAND.jpgyour welcome
        • mramlawi
          • Jul 2011
          • 838
          if this problem comes back again try this solutions , First of all change the power supply must work if not try the 2nd choice clean the filter of the fan that located on the back of the machine (MFC FAN) and dont let the copier be so close to the wall .if didnt work also Change the MFC BOARD and it will work C YA
          Distinguished road makes you jewel in rough
