dirty copies in IR 3180CI
  • mido
    • Nov 2011
    • 176
    the problem is yellow dirty copies when printing color or black, the cleaning blade of transfer belt changed the drum unit also changed, I am using original toner. look to the image to see the yellow backgound even when copying or printing black copiesimage.jpg
  • Canon.Tech
    • Mar 2009
    • 335
    Re: dirty copies in IR 3180CI
    Did you fit a new genuine Canon yellow drum unit?
    • mido
      • Nov 2011
      • 176
      yes all ate original
      • Simons
        • Jun 2008
        • 490
        Id check contacts on the transfer belt unit. You dont want something messing with your transfer rollers?
        • montana
          • Aug 2008
          • 393
          hi... is that happen when printing or copying???
          • Rachid.Akli
            • Oct 2011
            • 595
            IR3180C is a single drum color machine. If you've single color issues; verify , clean or change the corresponding dev unit.
            Rachid.
            "Find a job you love and you’ll never have to work a day in your life." Nagy's father
            • Canon.Tech
              • Mar 2009
              • 335
              Ah yes this is the 3170 series I was thinking of the 2880! Have you cleaned the patch sensor & run a full auto gradation?
              • mido
                • Nov 2011
                • 176
                this is series ir 3100 used one drum....
                • mido
                  • Nov 2011
                  • 176
                  nothing contacts the transfer belt only the blade, sure nothing missing, but when doing about five copies it becomes clean.
                  • mido
                    • Nov 2011
                    • 176
                    yes i cleaned all the internal units inside the machine and did auto gradation, but i noticed the yellow toner powder fall inside the machine as over toned
                    • mido
                      • Nov 2011
                      • 176
                      both printing and copying
                      • mido
                        • Nov 2011
                        • 176
                        pls look at the image that i sent to see the the problem
                        • mido
                          • Nov 2011
                          • 176
                          • mido
                            • Nov 2011
                            • 176
                            • mido
                              • Nov 2011
                              • 176
                              Rachid.
