iR 5000s E003
  • Toner Boy
    • Aug 2007
    • 365
    iR 5000s E003
    We replaced the main thermistor to bring it back alive, however we're still getting the code frequently requiring resets. Any other ideas of what could be causing it? AC power is sufficient, I know could be AC driver or DC controller but how likely would that really be...from our experience the thermostat is either good or bad - not intermittent.
  • its_just_a_copier
    • May 2011
    • 132
    Re: iR 5000s E003
    Try shimming the rear connector of your Fixing/Feed unit,
    or could be your Fixing/Feeding Connection PCB P/N FG5-4979-000
    • Toner Boy
      • Aug 2007
      • 365
      Re: iR 5000s E003
      I thought of that as well, I assume you mean adding a spacer to bring them both together more firmly - will give it a try, thanks.
      • its_just_a_copier
        • May 2011
        • 132
        Re: iR 5000s E003
        Yep, a washer or a hunk of paper or something.... Good Luck~!
