Jamming in IR 3170CI
  • mido
    • Nov 2011
    • 176
    Jamming problem in canon IR3170CI every copies in heater unit,
    the jamming in sensor no.PS14 delay type,
    what is the reason???
    thanks in advance.
  • zoraldinho
    teacher-guide-expert-guru
    • Mar 2008
    • 5000
    Re: Jamming in IR 3170CI
    Open and inspect the fuser.How old is fixing assy?
      • 2621
      Can you hear a clunking noise from the right door during warm up or copying?
      • zoraldinho
        • Mar 2008
        • 5000
        • vj200729
          print mate
          • 81
          the wire connecting sensor to chaise may be damaged
          • mido
            • Nov 2011
            • 176
            the old of the fixing unit is about 23%
            • mido
              • Nov 2011
              • 176
              yes i hear strange voice noise ... I think in the exit unit not exactly....
              • mido
                • Nov 2011
                • 176
                [ATTACH=CONFIG]17051[/ATTACH]
                hi my friend
                what do u mean this image???
                • mido
                  • Nov 2011
                  • 176
                  thanks my friend to your reply
                  the wire and the sensor are good
                  • Canon.Tech
                    • Mar 2009
                    • 335
                    If you can hear a clunking noise not a chicken "clucking" then your fixing unit is bad, the rollers get flat spots causing the noise & will cause jamming.
                    • mido
                      • Nov 2011
                      • 176
                      hi my friend
                      thank you very much for your reply,
                      the jamming occur while the copy starts to leave the fixing unit before arriving the exit senosr ps14
                      • mjarbar
                        This could be a problem with the 3-Way unit flapper. SL2 on the unit opperates the flapper to either pass the paper straight through for single side or divert it around for duplex printing/copying. If this has come out of place or sticks it will delay the paper getting to the delivery assy.
                        There have been a couple of similar posts for machines using the same 3-Way which I have posted below.
                        http://www.copytechnet.com/forums/canon/68195-ir4570-paper-jam-duplex-mode.html
                        http://www.copytechnet.com/forums/canon/57938-ir3035-duplex-jam.html
                        Hope this may help.
                        • tenatal
                          • Aug 2011
                          • 35
                          As u already know PS14 is delay sensor, the paper cannot get over to PS14 on time.
                          This may be due to -
                          The fixing (heater unit) get jammed (due to jamming of fuser roller bearing)
                          u must check fuser unit for free rotation by rotating the green knob of fuser unit
                          if it is heavy on rotation then bearings are gone, replace them.
                          • Rachid.Akli
                            • Oct 2011
                            • 595
                            You can verify the state of the deivery sensor (PS14) in: Service mode>I/O>DCCON>P002 bit 5.1: paper present.
                            Rachid.
                            "Find a job you love and you’ll never have to work a day in your life." Nagy's father
