canon it 3570 smears on top left corner
  • jake24482
    • Apr 2011
    • 116
    i am working om ir3570 smears on top left corner . i replace drum clean transfer roller . developer unit. nothing change .it just smears but no rub off.if some one had this problem please let me know .
    thanks in advance
  • arielcanon
    • Mar 2012
    • 106
    Re: canon it 3570 smears on top left corner
    thanks in advance
    post a picture please...
    Learning never ends..
    Never give up, where there is a wheel there is a way..
    • zoraldinho
      teacher-guide-expert-guru
      • Mar 2008
      • 5015
      Fixing film.
      • jake24482
        • Apr 2011
        • 116
        here are couple of pages .i replace drum ,transfer roller ,fixing film. it still doing it
        • zoraldinho
          • Mar 2008
          • 5015
          Use bigger format and check for smear repetition.Also you can make a force stop before fuser and
          inspect print quality.Read PDF........ir4570-045.pdf
          • CanonSco
            Man About Town
            • Jul 2010
            • 368
            I have 2 other things cause similar ( other than what you have replaced already )
            1) - very important to clean all the hard toner off the fuser input guide.
            2) - I have had several occasions where the transfer roller "box" on the RHS door that swings out does not mate with the machine side properly. If you close the door slowly whilst pushing the transfer assy into the door, letting go with your hand as late as possible so it mates correctly it will show you if it solves the image issue. You can then either replace the door or tie-wrap the assy hard into the rhs door. Dont see many original 4570 type machines now, but as they got a little longer in the tooth this was not uncommon.
            Yes, I am a nerd.
            Gaming PC - check. Raspberry Pi - Check. Custom ROM on phone - check. Thick glasses - check.
            • arielcanon
              • Mar 2012
              • 106
              try oem toner, check fixing film rotation, roll pressure, and bearing of pressure
              • Dougtech
                • Apr 2011
                • 113
                Before going any further I would do a stop test and try to catch it between the drum and fuser to see if your defect is present before fusing. with front door open it should be relatively easy. Then you will know where to "dig deeper" .
                You could also try a "skyshot" to get more image on the paper.
