ir 600 temp too high
  • taejing
    • Aug 2025
    when start in the morning , normally the temp of fixing will reach 200c ,and start to copy but now sometime it reach 205 c, before it happen I had clear ip in service mode, so how to adjust it to start at 200c ,thank you
  • nmfaxman
    • 1702
    Clean the thermistors and make sure you can fit your fist behind the machine.
    It will fluctuate one or two degrees.
    If these don't work check the ozone filters or any vents to make sure they are clean.
    Last check is power input.
    If A/C power is 20% lower than manufacuters recommended it will fail.
    Try turning machine on>>>>>count to 20. Turn machine off and then on and see if it comes to temp.
