imagePRESS 1135+/ 1135/ 1125+/ 1125/ 1110+/ 1110S+/ 1110P/ 1110S-Toner Bottle Message
    • 16083
    [Misc] imagePRESS 1135+/ 1135/ 1125+/ 1125/ 1110+/ 1110S+/ 1110P/ 1110S-Toner Bottle Message
    The Front Stopper becomes worn with use resulting in the lack of margin for gear engagement.
    This causes the gear on the toner bottle and the gear on the machine side to rotate without being engaged.
    see pdf's---
  • Zela
    • Mar 2014
    • 25
    Re: imagePRESS 1135+/ 1135/ 1125+/ 1125/ 1110+/ 1110S+/ 1110P/ 1110S-Toner Bottle Mes
    hello
    the same thing happened to me, but in the end I just changed (white) motor rotation toner was torn off the power cable in the motor.
    motor repaired and returned
    • zoraldinho
      teacher-guide-expert-guru
      • Mar 2008
      • 5018
      Good job!
      • khaled_abosere3@yahoo.com
        Head technical support
        • Mar 2012
        • 172
        see pdf's---
        I just ask this technical bulletin is useful with faint image?
