canon image runner advance 6055
  • bonny
    • Sep 2012
    • 6
    Dear All,
    can anyone cone across the issue below:
    After installing new canon iR advance 6055 all try are not working it is showing jam paper error from try one and two ,
    only bypass can work properly.
    any help or idea is highly appreciate
  • roller
    • 26
    Re: canon image runner advance 6055
    Originally posted by bonny
    Dear All,
    Recheck this steps of installation:
    • KL568
      _
      • Feb 2011
      • 324
      Is Tray 3 and Tray 4 giving paper jam too?
      If not, then pull out Left paper Deck and Right paper Deck, look for a white plastic block. Loosen 1 screw and move it to other direction.
      • canonbundy
        • Jun 2012
        • 607
        I come across these situations all the time with Junior or inexperienced Techs dealing with Canon Products - you MUST follow the Installation Instructions on all Canon Boxes especially the Advance Range - the other replies are correct, adjust the white nylon blocks from position 1 to 2 in Left & Right Decks (Cassettes 3 & 4 not affected).
        • bonny
          • Sep 2012
          • 6
          Thanks all for your support ; may God keeps blessing you .it is now working properly.
          what i facing now is that i can't enter management settings . i wanted to configure it to network
          with thanks ,
          Bonny
          • roller
            • 26
            with thanks ,
            Bonny
            Enter user mode and log in as administrator. Default u name and pwd is 7654321.
            • KL568
              _
              • Feb 2011
              • 324
              ID 7654321
              PIN 7654321
              You ought heed to advice given, get trained and get a service manual.
              You akin to driving a 4 by 4 Rover but holding a driving license of a 500cc motorbike.
              • bonny
                • Sep 2012
                • 6
                Thanks so much for your delicious supports.
                stay blessed
