Print driver for imagePass M2 on MAC OS 10.6.8
  • Ingranaggio_rotto
    • Oct 2010
    • 274
    And more ....
    I have a 8500 with imagePASS M2 iR that should be installed in a Mac OS 10.6.8 (Snow Leopard).
    They are the PPD for this operating system?
    Thank you for your help.
  • charm5496
    • 2387
    Re: Print driver for imagePass M2 on MAC OS 10.6.8
    the last PPD that was released for this imagepass was for OS.x 10.4
    It does not look like you are going to get the customers newer Mac to talk to this older imagepass
    • KenB
      Geek Extraordinaire
      • Dec 2007
      • 3945
      You're pretty much stuck here; maybe you can try a generic ppd, but you won't be happy with it.
      Assuming that this is for a customer, did he consult with you before attempting to do this?
      Let's see... I think I'll go with "No".
      • Ingranaggio_rotto
        • Oct 2010
        • 274
        It's not a good news..........
        • Ingranaggio_rotto
          • Oct 2010
          • 274
          I think that with a generic PPD certain functions are disabled ...
          • KenB
            Geek Extraordinaire
            • Dec 2007
            • 3945
            Did I not say that you wouldn't be happy with it??
            • charm5496
              • 2387
              generic PPD's basically allow you to output pages, sometimes duplex and that is about it.
              • KenB
                Geek Extraordinaire
                • Dec 2007
                • 3945
                Just a thought or two:
                Try downloading and installing Command Workstation for your Mac; version 4, not 5. (Version 5 won't support your RIP.)
                Convert all your print files to pdf (which your OS will do natively), and use Command Workstation to download the files. You may (or may not) get all the features.
                The issue is that your RIP and copier are not fully supported with that new a version of CWS, especially on a Mac.
                Keep in mind that it's only relatively recently that CWS was supported at all on the Mac OS platform.
                Or...
                The imagePASS M3 does support OSX 10.5, and the drivers can be downloaded from Canon. Again, absolutely no guarantees, but worth a shot.
                • Ingranaggio_rotto
                  • Oct 2010
                  • 274
                  Right! .... I could take advantage of the CWS 4.xx
