canon ir 2318 error code
  • RWAFA
    • Aug 2011
    • 68
    hi guyz, i have my canon ir 2318 which is showing any error code 0001-001, wht could be the problem,i have tried to clean the fusing thermo-start but the problem continues.does any one knows the problem?
  • mosey1100
    • Mar 2009
    • 143
    Re: canon ir 2318 error code
    Have you tried to clear the error in service mode? You might have to replace or rebuild the fixing unit.
    • gensys
      • Jan 2011
      • 324
      Abnormally high temperature (detected by sub thermistor)
      The sub thermistor detected an abnormally high temperature (300 deg C) during temperature control.
      Check sub thermistor
      Check the connector of the fixing film unit.
      Replace the fixing film unit.
      The Road will be Mastered by >>> the Going...
      • Rachid.Akli
        • Oct 2011
        • 595
        electric grid fluctuations. Put a stabilizing tension equipment.
        Rachid.
        "Find a job you love and youโ€™ll never have to work a day in your life." Nagy's father
