Canon cassette fix - C3200 and others
  • kuby
    • Oct 2007
    • 1400
    Is there a way to fix one of these cassettes after the gears break. I though I was something about fixing these somewhere.
    • 23007
    Re: Canon cassette fix - C3200 and others
    The method I use is pretty simple. It's the rear guide that floats free when the post breaks.
    I'll set the front guide for LTR (or whatever size desired), position the paper and rear guide temporarily, just long enough to run a few copies and check front to rear registration. Adjust if necessary.
    Drill a hole through the metal part of the rear guide, and through the cassette base, and countersink from the bottom for a M3x5 flathead screw. Tap the metal, and secure it with the screw.
    Re-check image registration and paper fit. If it still looks good, do the same on the front guide. It takes about 1/2 hour, and will never break without catastrophic damage to the tray. And then it would be billable. =^..^=
    • vigour
      • Aug 2010
      • 1038
      some guys set the guides as the previous post, and glue or screw down the rear guide.
      I remove a long self tapping screw from the front of the drum unit
      make a small hole with tiny drill bit or screwdriver at a strategic spot
      insert the long selftapper from the bottom
      this prevents it from going wider
      there is a 3rd party kit you can buy to make it work like new
      • teckat
        • 16083
        Cassette Body Gear Post Breaking
        see pdf for fix------Cassette Body Gear Post Breaking .pdf
        OR--- Omega Pro Fix
        CN101
        Canon Cassette repair starter kit with drill bit
        $24.95
        CN102
        Canon Cassette repair inventory kit (repairs 3 cassettes)
        $64.95
        http://omegaprofix.com/index.html
        • Canon.Tech
          • Mar 2009
          • 335
          The best way is to simply order a new casette, bill the customer & move on.
          The won't break it again! in a hurry!
          • kuby
            • Oct 2007
            • 1400
            Already ordered a new one, just wanted to know if there was a fix for these. Thanks
            • Canon.Tech
              • Mar 2009
              • 335
              It's not worth the hassle of repairing, just ship a new one to the customer, after all they broke it!
              • teckat
                • 16083
                where the Hell is that Paper Jam
