iR4570 ADF Problem on 8.5x13
  • goldencup
    • Nov 2008
    • 366
    Hi i have problem on iR4570 using the feeder on 8.5x13 only. When i try to feed an 8.5x13 original on feeder, the heading of the printout seems to move maybe an inch. Also same problem when i use the feeder on duplex mode. On top glass, the output is okay. Any adjustment to be made? Thank you very much. (see attached image)
    <ORIGINAL <OUTPUT
    • 23009
    Re: iR4570 ADF Problem on 8.5x13
    I don' know about the Philippeans, but in the US 8 1/2" x 13" or Folio is not a standard US paper size. My guess is that your 4570 is interpreting it as 8 1/2" x 14" or Legal, then trying to make the image fit.
    If the option is available, I would be looking for original size detection settings, specifically Folio. =^..^=
    • teckat
      • 16083
      <ORIGINAL <OUTPUT
      try these settings below
      in Level 1 / set to "3" below
      COPIER > OPTION > BODY>MODEL-SZ
      3: AB/INCH (6R5E)
      Setting a special paper size that cannot be recognized by DF-
      Level 2
      COPIER > OPTION > BODY>ORG-LGL
      <Setting range> "3" is for Folio/ "4" is G-Legal=both are same size
      try to set at "3" or "4" see what happens
      • goldencup
        • Nov 2008
        • 366
        Just want to say "Thank You!" to both of you Problem solved.
        Here are the adjustments (just in case someone have the same problem.)
        ADDITIONAL FUNCTION>2>8>ADDITIONAL FUNCTION (for Level 1)>COPIER > OPTION>BODY>MODEL-SZ 3: AB/INCH (6R5E)
        ADDITIONAL FUNCTION>2>8>ADDITIONAL FUNCTION (for Level 1)>ADDITIONAL FUNCTION>2 (for Level 2)>COPIER>OPTION>BODY>
        ORG-LGL 1: FOOLSCAP
        ADDITIONAL FUNCTION>2>8>ADDITIONAL FUNCTION (for Level 1)>FEEDER>ADJUST>DOCST>
        Adjusting the front position of document image <Adjustment method> Setting a greater value delays the image front timing. (do a trial and error, mine is -5)
        • teckat
          • 16083
          The Dude.jpgthanks
