CYLINDER DEVELOPING
  • zibros
    • Sep 2012
    • 31
    [Misc] CYLINDER DEVELOPING
    Hallo every body,
    This is just a discussion, you know the cylinder developing is expensive enough. I think we need a solution to repair the cylinder. We know the cylinder is plated by magnetic material. Any body has experience how to plating the cylinder with magnetic?, is it has a risk to machine?
  • teckat
    • 16083
    Re: CYLINDER DEVELOPING
    Originally posted by zibros
    Hallo every body,
    remove & wipe off dev/toner---then clean the cylinder with BRASSO CLEANER> Wipe off with water >let dry
    • zibros
      • Sep 2012
      • 31
      I mean, the plating magnetic of cylinder was finished (white color). Is that possible we plate the cylinder again with magnetic?
      • teckat
        • 16083
        NO~~~~~~~~~~~~~~~~~~~~~~
        • roller
          • 26
          The magnet is actually inside the cylinder. The cylinder itself is made of aluminium. All you can do is what teckat says...
          • zibros
            • Sep 2012
            • 31
            OK, I am agree
            by the way, just want to know, what is the material (black) draped the cylinder?
            • Canon.Tech
              • Mar 2009
              • 335
              If a developer roller is worn then it is time to replace the developer unit as the bearings, spacers etc will also be worn (depending on model)
              • roller
                • 26
                OK, I am agree
                Most likely anodized aluminum.
                • mramlawi
                  • Jul 2011
                  • 838
                  what kind of human u are !!! change the Cylinder Fastly without wasting ur time and make yourself Smart
                  Distinguished road makes you jewel in rough
                  • jiongpao
                    • May 2009
                    • 413
                    What im thinking is theres a magnetic thing inside the cylinder. Must be handle with careful. I drop it once before to the solid ground and causing the magnetic broken inside. Then i assemble back to developer unit hoping it will run perfectly but the result will be uneven dirty copy at background.
                    • canonbundy
                      • Jun 2012
                      • 607
                      Ho Hum
