insert Drum canon ir2545
  • sahara
    • Sep 2012
    • 18
    I have one canon machine and it is showing insert drum,I have tried so many ways but it does not work.The message Insert drum still there even though we replaced with a used one.We swapped the same drum in other machine and it is working well,The machine is showing ready signal with the message insert drum and is not able to copy or print
    Last edited by sahara; 09-22-2012, 11:46 AM. Reason: The reply is not enough to remove the message insert drum
  • zoraldinho
    teacher-guide-expert-guru
    • Mar 2008
    • 5015
    Re: insert Drum canon ir2545
    installing the drum unit.pdf
    • kstan268
      • Apr 2012
      • 85
      had you solve this problem..becouse i had the same issue need help thank you
      • teckat
        • 16083
        Originally posted by githenhi
        • REGSIS
          • May 2016
          • 435
          It's the HV board.
          Try to remove it, clean the contacts and put it back. 10 min work.
          If that fails replace it from working machine just to confirm that's the cause of the problem.
          After that order a new one.
          • Kings
            Steve@Kings
            • Nov 2009
            • 79
            Originally posted by REGSIS
            It's the HV board.
            I've also had this a few times and if it hasn't been the grounding contact inside the drum it has always been the HV board..
            Good luck
            • montana
              • Aug 2008
              • 392
              i believe it is the HVboard
                Originally posted by teckat
                [ATTACH=CONFIG]39936[/ATTACH]
                yeah he was canned about a month ago...damn spammers
                • kstan268
                  • Apr 2012
                  • 85
                  My case is different .After replace HVT,Drum and PSU still problem occur..last i order a DC controller(Fm4-28640 Problem solve yeah
