canon ir 5055
  • Saji
    • May 2010
    • 97
    canon ir 5055
    Canon ir 5055 showing error E100-001, tried to reset it, but no avail, changed laser unit and Dc board, still some times it still shows up,open the front door and close it, machines start working,but error again shows up afer a few thousand copies, wht could be the problom, pls help.thnaks in advance.
  • zoraldinho
    teacher-guide-expert-guru
    • Mar 2008
    • 5014
    Re: canon ir 5055
    Door switch? Power supply?
    • mramlawi
      • Jul 2011
      • 838
      Re: canon ir 5055
      the front cover switch is the problem make sure that the shutter of the front cover is closing normally , trouble shoot it bye puting a a flat screw drive on the switch
      Distinguished road makes you jewel in rough
      • roller
        • 26
        Re: canon ir 5055
        Check the process unit cover. There is a pin pressing on the laser shutter. Maybe a screw is missing or broken shutter?
        cover.pdf
        • lynden
          Re: canon ir 5055
          have you chick the sensor maybe there is broken part in side just review where you start to open...
