canon ir2022
  • montana
    • Aug 2008
    • 392
    canon ir2022
    hi,,,ir 2022 when i power the machine on the initialization bar stop in the middle and stay there....is there
    any suggestion about this issue???
  • mramlawi
    • Jul 2011
    • 838
    Re: canon ir2022
    looks like the dc contraller fault
    Distinguished road makes you jewel in rough
    • teckat
      • 16083
      Re: canon ir2022
      LAN pcb may be faulty. This is the pcb that the network cable plugs into and is also referred to as the NIC (Network Interface Card) by some people-
      unplug LAN pcb from printer> & power up >
      if ok on power up / LAN Pcb could be defective
      DDR module can also be defective / remove and re-seat/or replace
      the none 'I' model has only one DDR module
      • Rachid.Akli
        • Oct 2011
        • 595
        Re: canon ir2022
        Hi to all
        The issue is probably due to the main controller more than the Dc controller.
        Rachid.
        "Find a job you love and you’ll never have to work a day in your life." Nagy's father
        • montana
          • Aug 2008
          • 392
          Re: canon ir2022
          hi....thanks guys..i'll try and feedback
