IR4570 Shadow upper right Corner
  • fornerm
    • 82
    Hello,
    the Problem is on IR4570 on Single Copy oder more on A4.
    I Change Paper Typ, DV Unit, Laser Unit, its the same.
    See the Example. It is on the Paper before the Paper go in Fixing Unit.
    The Shadow is on the upper right Corner, even then i print a Testpage from
    Service Menu.
    Look the Atachment.
    Have anybody a Idea ?
    Thanks a lot.
  • Cabo
    • Aug 2012
    • 41
    Re: IR4570 Shadow upper right Corner
    Try to clean led array
    • r3d343420
      • Aug 2012
      • 56
      Does the defect appear on the drum when you do an emergency stop? is everything clean inside the right door?
      • Canon.Tech
        • Mar 2009
        • 335
        Have you tried a new drum unit (Canon) & are you using genuine Canon toner?
        • mramlawi
          • Jul 2011
          • 838
          change a new drum , or check the cylander
          Distinguished road makes you jewel in rough
          • fornerm
            • 82
            Hello all,
            thanks for answer. LED Arry is clean and i change for test. Drum is change too, Toner is canon org.
            all is clean.
            the latete picture on drum unit is ok, no Shadow; Now the Picture on Paper before fixing is ok.
            after further troubleshooting, i can say.......
            The error occurs when the paper is between the drum and Fixing Unit or before it in the fixing is running.
            something like that, maybe a Guide Problem..?
            the image is blurred ?.
            but I do not know what I can do about it
            Something Ideas ?
            regards
            • Mina Banoub
              • May 2011
              • 50
              Originally posted by fornerm
              Hello all,
              all is clean.
              Something Ideas ?
              regards
              Replace the fixing film Ass`y
              • fornerm
                • 82
                yo, i replaced the complete Fixing Assy. And ? The Same..
                Does anyone have the possibility to search for technical information at Canon ?
                • Dan Dryer
                  • Jan 2008
                  • 57
                  Check the condition of the Static Eliminator. If there's any damage or paper fragments stuck there, it can cause this type of toner scattering or blurring at the lead edge.
                  There's also a setting in service mode COPIER>OPTION>BODY>FIX-SMR which changes the Dev bias and may help with this issue.
                  • Eric1962
                    It is possible that this is the position of the side door is not correctly positioned
                    • fornerm
                      • 82
                      to Dan Dryer:
                      Sounds good, I'll try it......
                      to Eric1962: I too have thought, but could find nothing ..............
                      • tinnyjay
                        • Oct 2009
                        • 663
                        Hello,
                        Service Menu.
                        Look the Atachment.
                        [ATTACH]17360[/ATTACH]
                        Thanks a lot.
                        First you make a print and see if the problem is the same like copying.
                        I dont want to debate,but it looks like you are "cheating" us,because drum,developer unit,bad toner,cleaning blade,coronas doesnt cause this problem.
                        Is the same dirty image in the same place of paper!!!!
                        If this problem is real,you must check up scanner components.
                        Clean the glass of copier and lens and it will be ok.
                        PS A bad motherboard could also cause this!
                        "Who loves the roses,must also bear thumbs"
                        • jake24482
                          • Apr 2011
                          • 116
                          check the side door position make sure every thing is OK on door assembly. I think the problem in in door assembly.I had a same problem and replace every thing like drum ,DV,fixing assembly .That did not take care of the problem door did
                          • arielcanon
                            • Mar 2012
                            • 106
                            Let's think positive, no problem, just see what happen next..., we have many experience people here..
                            poster already said > The Shadow is on the upper right Corner, even then i print a Testpage from
                            Service Menu.
                            means thats process is problem (without using scanner)
                            Learning never ends..
                            Never give up, where there is a wheel there is a way..
                            • fornerm
                              • 82
                              Update to Dan Dryer:
                              i tested Fix_SMR several Week, Problem could not be resolved and is still current.
                              Maybe I'll try the door yet. I think not, but anything is possible
