finisher F1 , canon ir 5000
  • adel_nathan
    • Jul 2011
    • 103
    hi every body
    i need help
    i have finisher canon model F1 work on photocopy canon model IR5000
    it's working normaly for alot of copeis ( may be reach to 800 sheet continusly )
    but sudenly jamed in buffer ( befor entering swing ) and give jam code 1134 , and this is the same place which jam take place
    i dissconnecet the finisher and test photocopy alon , no jam happened
    please help me
    thanks
  • adel_nathan
    • Jul 2011
    • 103
    Re: finisher F1 , canon ir 5000
    is there any idea
    please help
    • zoraldinho
      teacher-guide-expert-guru
      • Mar 2008
      • 5000
      We have discussion about code 1134 here.........http://www.copytechnet.com/forums/ca...-1134-2-a.html
      • teckat
        • 16083
        Originally posted by adel_nathan
        is there any idea
        please help
        1134= could occur due to excessive pressure of the shaft (FB3-7288-000) and the front and rear bushings (FS5-1805-000).
        Remove the shaft (FB3-7288-000) and polish both ends so that they will turn and move freely inside the bushing (FS5-1805-000). These parts are pictured in the parts catalog on page Q37 items #5 and #23.
        1134= can be caused by the swing guide not opening. A quick way to check the swing guide is to turn the copier off and on. When the finisher is initializing the swing should open and close.
        When the finisher is initializing if the swing guide doesn't open, it has been found that PI18 can cause this problem. Page 2-27 in the finisher manual shows a figure on the swing guide. PI18 part number is WG8-5364-000.
        • adel_nathan
          • Jul 2011
          • 103
          thanks
          solved by cleanning shaft and bushing
          thanks alot
          • teckat
            • 16083
            thanks
            thanks alot
            zoraldinho pointed all in right direction'
            Mafia-Man.jpg"prego"
