Ir4570 a4 paper jam in single side but not a4r
  • daya
    • Aug 2025
    [Jamming] Ir4570 a4 paper jam in single side but not a4r
    IN IR4570 paper jam while printing single side and double A4 paper and also xerox, but A4r is printing well without get jammed in both single and double side
    the jam error is 0107 plz help ,
  • kuby
    • Oct 2007
    • 1409
    Re: Ir4570 a4 paper jam in single side but not a4r
    First off check your paper tray setting to make sure the cassette is set to the proper size. Check and or replace feed rollers if needed.
    • daya
      roller are change and size are set perfectly in the tray,
      the paper get folded and jammed
      • zoraldinho
        teacher-guide-expert-guru
        • Mar 2008
        • 5015
        Do you have fully upgraded copier with new tipe of lower door,vertical path rollers etc......?
        • daya
          plz tell about this problem
          all the major parts are fine rollorer door etc, because A4r is printing fine only A4 is problem,,
          plz replayhelpful solution
          • Canon.Tech
            • Mar 2009
            • 335
            Do a single side copy, does the paper come out curled? If it does than your paper is damp. Try a new packet of paper & also try 100GSM if you have any.
            • teckat
              • 16083
              is A4 jam from only one cassette / or deck location ??
              • daya
                even if placed 90gsm and 100gms paper also it get jam.
                and in both cassette A4 is getting jam,
                and after continues use of A4r it also get jam its after 100 to 170 pages
                no curve paper in single printing , the paper is fine
                plz help
                • teckat
                  • 16083
                  plz help
                  is this jam issue from network prints ? or glass copies or both ?
                  Check your entrance guide --
                  • daya
                    both from glass and network printer
                    • ernesto
                      • Oct 2011
                      • 430
                      hi, have you read Zoraldinho post ?
                      can you take a picture ?
                      all the best
