iRAD8000/6000--Light Density Image Fault/Defective Developing High Voltage Contact
  • teckat
    • 16083
    [CQ] iRAD8000/6000--Light Density Image Fault/Defective Developing High Voltage Contact
    Light Density Image Fault Due to a Defective Developing High Voltage Contact
    The contact between the Developing Assembly and the Developing High Voltage Contact Unit on the main body may become oxidized. If this should occur, the density of the entire image will be very light.
    Products Affected: Serial Numbers Affected:
    imageRUNNER ADVANCE 8105 V2 --HMU11531 and earlier
    imageRUNNER ADVANCE 8105G V2 --HMV10045 and earlier
    imageRUNNER ADVANCE 8095 V2 --HNA12489 and earlier
    imageRUNNER ADVANCE 8095G V2 --HNB10073 and earlier
    imageRUNNER ADVANCE 8085 V2 --HNG10923 and earlier
    imageRUNNER ADVANCE 8085G V2 --HNH10091 and earlier
    imageRUNNER ADVANCE 6075 V2 --HTK16543 and earlier
    imageRUNNER ADVANCE 6075G V2 --FZQ10429 and earlier
    imageRUNNER ADVANCE 6065 V2 --HTP15099 and earlier
    imageRUNNER ADVANCE 6065G V2 --FZZ10349 and earlier
    imageRUNNER ADVANCE 6055 V2 --HTT26076 and earlier
    imageRUNNER ADVANCE 6055G V2 --GAJ10712 and earlier
    SEE PDF----Light Density Image Fault Due to a Defective Developing High Voltage Contact.pdf
