7055 E503-0003
  • nogood boyo
    • Mar 2012
    • 156
    [Electrical] 7055 E503-0003
  • zoraldinho
    teacher-guide-expert-guru
    • Mar 2008
    • 5006
    Re: 7055 E503-0003
    Did you inspect communication between Finisher and copier? (and professional puncher)
    Check connector on the integration unit controller,connector on the professional puncher
    controller.
    • nogood boyo
      • Mar 2012
      • 156
      Re: 7055 E503-0003
      not with a multi-meter,
      but other wise all connections appear good and intact.
      *also this error has been popping up every day since the machine was installed (five months ago) i only just found out about it last week.
      is it possible that the machine was set up incorrectly?
      • vigour
        • Aug 2010
        • 1038
        Re: 7055 E503-0003
        [QUOTE=nogood boyo;315146]
        I swapped out the punch controller pcb assembly and had a new error pop up
        505-0002
        so I put the original PCB back in.
        E505-0002 on a new board means you have to do sensor init and set the number of punches
        Some new finisher controllers also pop a code untll you do the adjustments.
        Put the new board back and do the adjustments
        • nogood boyo
          • Mar 2012
          • 156
          Re: 7055 E503-0003
          [QUOTE=vigour;315309]
          505-0002
          E505-0002 error code locks me out of this menu i thought?
          settings/ registrations button right?
          is there a chance this could be firmware related?
          • nogood boyo
            • Mar 2012
            • 156
            Re: 7055 E503-0003
            505-0002
            BUMP.
            Revisiting this problem. Thought that i had it fixed without replacing the Punch Controller PCB... looks like i was wrong
            Does anybody know where in service mode i perform a sensor initialization for the punch unit? Adjust the number of punches?
            While at this point i have completely stripped and rebuilt this model of machine a couple of times, i haven't officially been trained on this model and Canon Tech Support is reluctant to assist me.
            Any help will be appreciated, save me from searching through the service manual.
            Thanks heaps.
            -Nogood
            • nogood boyo
              • Mar 2012
              • 156
              Re: 7055 E503-0003
              Also: lol at my last post on this subject. Oh, how i've grown.
              [QUOTE=nogood boyo;315521]
              • vigour
                • Aug 2010
                • 1038
                Re: 7055 E503-0003
                From my manual
                5.3.1.2 Sensor Output Adjustment
                0023-7182 Perform this adjustment when replacing the punch controller PCB, transmittance
                sensor (photosensor PCB/LED PCB), or deflection sensor (scrap full
                detector PCB unit).
                1) Check that the power of the host machine is off and then remove the rear
                cover of the puncher.
                2) Set SW601 on the punch controller PCB as shown below.
                F-5-1
                3) Turn on the power of the host machine.
                4) Press SW602 on the punch controller PCB. Sensor output is adjusted automatically
                when the switch is pressed.
                Adjustment is complete if LED601 and 602 on the punch controller PCB
                flashes alternately.
                5) Press SW602 or 603 on the punch controller PCB to end the adjustment
                mode and set all bits of SW601 to OFF.
                6) Turn off the power of the host machine.
                5.3.1.3 Registering the Number of Punch Holes
                0023-7183 This operation registers which puncher unit is attached to the IC on the punch
                driver PCB so that the puncher unit can be identified by the finisher. For this
                reason, this operation must be performed when the punch driver PCB has
                been replaced.
                F-5-2
                4) Press SW602 on the punch controller PCB to select the number of punch
                holes.
                The items in the following table are displayed repeatedly from top to bottom
                each time SW602 is pressed.
                T-5-3
                5) Press SW603 on the punch controller PCB. The number of punch holes is
                registered to the punch controller PCB each time the switch is pressed.
                Registration is complete if LED601 and 602 on the punch controller PCB
                6) Press SW602 or 603 on the punch controller PCB to end the adjustment
                7) Turn off the power of the host machine.
