[Repair]DC controller ir5065
  • makmee
    • May 2012
    • 24
    Hi all,
    I have DC controller ir5065
    I need Repair
    I need Circuit Diagram
    Send to pm or post
    Thanks in advance
  • zoraldinho
    teacher-guide-expert-guru
    • Mar 2008
    • 5015
    Re: [Repair]DC controller ir5065
    dc con ir 5065.pdf
    • Herrmann
      • Jan 2006
      • 792
      Just a Hint: There are several fuses soldered on this bord, mostly of yellow or orange color, check them first and if defect, replace. I have repaired several Controllers this way, saving large amount of $
      If sometimes you feel a little useless, offended and depressed always remember that you were once the fastest and most victorious sperm of hundreds of millions!
      • makmee
        • May 2012
        • 24
        Originally posted by zoraldinho
        [ATTACH]17673[/ATTACH]
        Thank you very much
        • makmee
          • May 2012
          • 24
          Thank you For ideas
          • Simons
            • Jun 2008
            • 490
            do you have the toner problem e025 or something? Blown fuse.
            • mehta
              • Oct 2010
              • 11
              Thank you very much.
              • mehta
                • Oct 2010
                • 11
                Due to faulty toner motor fuse blown in DC controller PCB
                Replace motor and fuse in dc.
                  this thread is 8 years old...
                  dead thread.
