IR 5050 image problem
  • cobra
    • Dec 2011
    • 48
    I am servicing a Canon IR 5050. The copy output looks like the attached file. I'm suspecting a developer problem but on initial check it looks ok. Have you encountered image problems like this? And what could be the causing it. Thanks for your help.
    sample copy.pdf
    COBRA
  • Canon.Tech
    • Mar 2009
    • 335
    Re: IR 5050 image problem
    But I would check, clean & rewire the primary & transfer coronas, might be one of them arching.
    If you have time maybe remove & clean the drum.
    What count does the machine show?
    • cobra
      • Dec 2011
      • 48
      Thanks for the inputs i'll check primary and transfer chargers. Machine's total counter is 200,000.
      COBRA
      • Canon.Tech
        • Mar 2009
        • 335
        That's a low count for that model, you won't need to clean the drum.
        Is it being used with Genuine Canon toner?
        • zoraldinho
          teacher-guide-expert-guru
          • Mar 2008
          • 5015
          Look like developer cylinder faulty.
          To add..Technicians; Please post PG-test and not copy samples!
          • copyprint
            • Oct 2012
            • 18
            [ATTACH]17768[/ATTACH]
            just wipe your mg roller with dump cloth while rotating several times then do a test
            • cobra
              • Dec 2011
              • 48
              I have attached 5 output of PG-test #5. checked and clean developing unit, primary and transfer chargers. Should I consider replacement of developing unit?
              sample PG- #5 test output.pdf
              COBRA
              • cobra
                • Dec 2011
                • 48
                Yes they are using genuine canon toner. Checked and clean the primary and transfer charger and the developing unit. Still the same problem. Should I replace the developing assembly?
                COBRA
                • teckat
                  • 16083
                  yes
                  • COPIERTEC ASSOCIATES
                    • Aug 2011
                    • 279
                    From the look at your sample PG,we need to observe the following;
                    1.If the problem is consistent,check on the spacers of the dev unit and the supportive bearings.
                    2.If the problem is intermittent,check on the charger blocks and possible dry joints on the HVT.
                    The HVT could be sending more current hence a sparking of the corona wires.
                    • MK.
                      • Oct 2012
                      • 14
                      It seems the problem of mechanical drive to developing unit.Pls check that also.
                      • tongee
                        • Nov 2009
                        • 50
                        Replacement FH2-9246-020 CONNECTOR, HIGH-VOLTAGE
                        • cobra
                          • Dec 2011
                          • 48
                          Just to update. I had replaced the developing assembly and the trouble was fixed. But unfortunately the trouble returned again after 1 month. Is there something else I need to check besides the developer? Is there an adjustment when you install a new developing assembly? I really need your inputs as I'm going blank on this. Thanks
                          COBRA
                          • zoraldinho
                            • Mar 2008
                            • 5015
                            Definitely- when you install new developer:COPIER > FUNCTION > INSTALL>TONER-S hit OK
                              • Aug 2011
                              • 279
                              Like i said before, check on the HVT and replace the corona wires on both
                              the main charger and the transfer corona assemblies.
                              Also try to switch off and On the drum potential by going to service mode
                              and perform this;COPIER>OPTION>BODY>PO.If the drum potential PO is
                              reading 0(zero),change to1(one) and make test copies and vice-versa.
                              Good luck.
