Print out problem Canon IRC1028i
Re: Print out problem Canon IRC1028i
28lb paper is good for saturation
COPIER > FUNCTION > SPLMAN
there are 17 adjustments under SPLMAN
SPLMAN "0" is the default setting meaning all are are set to OFF
in your case some need to be set on-
see------
SPLMAN Settings.pdf
- The photosensitive drum consumption is affected by the drum rotation time.
At monochrome printing of plain paper or transparency, the photosensitive drums of Y, M, and C are disengaged from the ETB so that they do not rotate. In this condition, the sheet is attracted to the ETB by an attraction bias and fed to the black color photosensitive drum.
However, when feeding thick paper and envelopes, the photosensitive drums of Y, M, and C are engaged with the ETB because the absorption power by the attraction bias is weak for such media.
- This control is executed every time the printing mode is switched. When mixed printing of color and monochrome is performed, the print speed is reduced due to engagement/disengagement of the transfer roller.
In the machine, the transfer roller is engaged with or disengaged from the photosensitive drum via the ETB to reduce the color photosensitive drum consumption at monochrome printing.
The transfer roller engagement/disengagement control is executed at the following timing.
- Multiple initial rotations at power-on
- Multiple initial rotations at door closing
- Image stabilization control
- Printing operation
The status of engagement/disengagement during printing operation differs depending on the printing mode (monochrome or color mode).
This control works with the developing cylinder engagement/disengagement operation.
Service mode:
To prevent reduction of the print speed at mixed printing of color and monochrome, set the transfer roller to color mode (in which all color transfer rollers are engaged with the photosensitive drum).
COPIER> FUNCTION> SPLMAN> SPL53649
**However, when this setting is made, the color photosensitive drum is consumed even at the time of monochrome printing.
**Knowledge is time consuming, exhausting and costly for a trained Tech.**Comment
