Print out problem Canon IRC1028i
  • mark121381
    • Jul 2011
    • 85
    Hello,
    Need help on this. Is there someone here encountered this problem.IMG_4075.JPG IMG_4073.JPG This are the print outs coming from Canon IRC1028i. I did some trials to fix this problem but all are failed, I tried Auto adjust gradation and replacing new Fixing Ass'y but still problem occurred. It is only happened when printing from computer with images or pictures as you seen on my attachment.Any ideas on this, really appreciate your help, thank you in advance.
  • zoraldinho
    teacher-guide-expert-guru
    • Mar 2008
    • 5018
    Re: Print out problem Canon IRC1028i
    1. OEM toner
    2.In driver select maximum weight paper.(not enough temperature)
    3.Try with different paper.
    • teckat
      • 16083
      Originally posted by mark121381
      Hello,
      Need help on this. Is there someone here encountered this problem. This are the print outs coming from Canon IRC1028i. I did some trials to fix this problem but all are failed, I tried Auto adjust gradation and replacing new Fixing Ass'y but still problem occurred. It is only happened when printing from computer with images or pictures as you seen on my attachment.Any ideas on this, really appreciate your help, thank you in advance.
      remove and check your fix unit/inspect
      looks like u have a fuse temperature issue/ paper type ??
      Fixing Sleeve Pressuring/releasing Control
      machine controls the pressure between the fixing sleeve and the fixing pressure roller as needed to prevent the fixing failure and the breakdown of fixing assembly--
      Check the nip width by following the procedure below if poor fixing image defect occurs.
      1) Make an all solid black print of A4 or Letter size using an toner cartridge same as for this machine, and take the print to the customer's site.
      2) Place the solid black print, with the printed side facing DOWN, in the cassette of the printer.
      3) Press the test print switch.
      4) Open the upper cover as soon as the leading edge of the paper appears in the delivery slot. Leave it for ten seconds.
      5) Turn OFF the machine and take fixing unit from the machine. Then take the paper out from the fixing unit.
      6) Measure the width of the glossy band across the paper and check that it meets the requirements
      i believe in your model is same as iRC1030 >
      The fixing temperature controls are divided into the following 4 types.
      Initial rotation temperature control
      CPU firstly turns ON the fixing heater for a specified period at power-ON and then, drives the fixing motor.
      In a low temperature status such as at initial operation, the fixing sleeve may get damaged when the paper is fed because the grease inside the fixing sleeve is not
      yet smooth enough.
      This control is to melt the grease inside the fixing sleeve by heating the fixing heater before the fixing motor drives and to lubricate the sleeve in order to prevent the fixing sleeve from being damaged.
      Fixing sub thermistor (TH2) is used to detect the temperature.
      Start-up temperature control
      CPU heats the fixing heater to the start-up temperature in order to warm the fixing assembly up to the required temperature for fixing.
      The start-up temperature varies depending on the elapsed time since previous print completion, paper types, and environments.
      Print temperature control
      CPU maintains the temperature of the fixing sleeve at its targeted temperature during print operation.
      CPU gradually switches the target temperature in one printing process depending on the number of print. The targeted temperature varies depending on the paper
      types.
      The fixing main thermistor (TH1) is used to detect the temperature.
      Between-sheets temperature control
      At the continuous printing in low-speed mode, the pressure roller may be overheating between sheets.
      CPU reduces the temperature of hexing heater below the normal fixing temperature between sheets. The targeted temperature varies according to the between-sheets
      intervals and the paper types.
      At continuous printing with the paper width narrower than A4 size (210 mm), the end of fixing sleeve may overheat.
      If no paper is detected by the paper displacement sensor (SR714) on the registration roller at paper feed and, in addition, a detected temperature by the fixing sub
      thermistor (TH2) exceeds the specified temperature, it is considered that either universal size paper or narrower width paper than A4 size is fed.
      try this>>>>>>>>>>>
      change FRFS -Temp to "2" the default value is zero. The change can be made in service mode Copier > Adjust > VIFADJ > FRFS.
      looks like part stuck to pressure roller
      This is a repeated image >>>>>>>>>>>>>
      • Rachid.Akli
        • Oct 2011
        • 595
        Originally posted by zoraldinho
        1. OEM toner
        Hello,
        I once had the same issue with this model. The machine couldn't fixe that amount of toner (image) in that type of paper. So, as proposed by Zoraldinho, Try to slect a heaviest paper so that the machine increases its fixing time (lower fixing speed) or change the paper that would be able to fixe a higher amount of toner.
        Rachid.
        "Find a job you love and you’ll never have to work a day in your life." Nagy's father
        • mark121381
          • Jul 2011
          • 85
          Originally posted by teckat
          [ATTACH=CONFIG]17848[/ATTACH][ATTACH=CONFIG]17849[/ATTACH]
          yet smooth enough.
          types.
          try this>>>>>>>>>>>
          Sir Teckat,
          Hello Sir, thank you for this info. but Sir I already replaced new Fixing Ass'y , because we also think that Fixing Ass'y was the reason why the image repeated but problem still occurred. Sir I need to try the changing of FRFS -Temp to "2" in service mode. I believe something happened on the settings in service mode. Do you have settings or where i can find default settings list on the service mode. I tried to look inside the machine but I did not find the written settings usually find inside cover. and also Sir What is the best paper type I can recommend to use, usually we use here A4 size which is 80gsm. any advice. thank you again.
          • mark121381
            • Jul 2011
            • 85
            1. OEM toner
            Hello Sir,
            (.In driver select maximum weight paper.(not enough temperature) < as you mentioned here, How can I change in the driver for selecting weight paper?
            Thank you for your help
            • zoraldinho
              • Mar 2008
              • 5018
              Example
              • teckat
                • 16083
                READ-----
                Paper Requirements.pdf
                Heavy 2 can not be used it cassette
                only Stack Bypass=From 32 to 47 lb (121 to 176 g/m2)
                there is no service label in the machine, printing in the service mode setting value is not available either.
                Hence, adjustment in the market is being performed. Please note that when the value service mode is modified, be sure to record the modified value.
                When PCB is replaced or RAM clearing is performed, the adjusted ADJUST and OPTION value will return to default value.
                bottom line is >
                U NEED A MANUAL
                NIP CHECK (SEE ABOVE)
                Replace the fixing unit if the nip width is out of specification, since the nip width of the fixing unit is not adjustable in this machine.
                Service Mode
                1) Main menu key
                2) 2 key
                3) 8 key
                4) Main menu key
                The change can be made in service mode> > Copier > Adjust > VIFADJ > FRFS.
                FRFS-TMP
                Fixing temperature front side setting value
                [When used]
                The problem cannot be eliminated by performing special printing process and the image is not firmly fixed to the sheet, or a residual image remains in the image.
                [Caution] The fixing heater temperature is changed via this mode, and therefore, attentions should be paid when using this mode.
                [Adjustment method]
                - When an image is not firmly fixed to the sheet, the problem may be eliminated by increasing the setting value.
                - When a residual image remains in an image, the problem may be eliminated by decreasing the setting value.
                Setting range: -4 to 4 (Unit: Approx. 5 degree C)
                [Factory setting value/Value after RAM clearing: 0]
                BKFS-TMP Fixing temperature backside setting value
                [When used]
                in the image.
                [Adjustment method]
                • mark121381
                  • Jul 2011
                  • 85
                  Example
                  Thank you sir, I will try this one
                  • mark121381
                    • Jul 2011
                    • 85
                    READ-----
                    [ATTACH]17855[/ATTACH]
                    bottom line is >
                    U NEED A MANUAL
                    Service Mode
                    1) Main menu key
                    2) 2 key
                    3) 8 key
                    4) Main menu key
                    FRFS-TMP
                    [When used]
                    [Adjustment method]
                    [When used]
                    in the image.
                    [Adjustment method]
                    Hello Sir Teckat,
                    This is very helpful to me. I did change FRFS -Temp to "2". Right now we see some changes on print out but sometimes repeated image still occurred. Need some observation on this and trying adjust some value of the settings as you mentioned on adjustment method.
                    • teckat
                      • 16083
                      try this
                      change COPIER>ADJUST>VIFADJ>FRFS-TMP to a "2" and COPIER>ADJUST>VIFADJ>BKFS-TMP to a "2" in Service Mode.
                      Then in User Mode go to -
                      Additional Functions>Adjustment/Cleaning> and perform a Fixing Unit Cleaning.
                      are you using Canon OEM Toner
                      • mark121381
                        • Jul 2011
                        • 85
                        try this
                        need to update this thread, still I'm facing this problem. Im using original drum toner which coming from japan. I also change new fixing unit ass'y on this machine but still got this problem. Just want to ask is there any other parts need to replace? I am concluding the parts of video controller board. Do you think there is relation on this parts?
                        • SCREWTAPE
                          East Coast Imaging
                          • 3396
                          Video controller. Unlikely..
                          This machine is not design for this type of output. This is a desktop printer.
                          To much saturation. That fixing element isn't made to fused that kind of toner saturation.
                          Give up.
                          Get yourself and MFP.
                          I'm not trying to be rude.
                          But it is what it is.
                          • teckat
                            • 16083
                            THERE ARE PAPER TYPE SETTINGS UNDER
                            COPIER > FUNCTION > SPLMAN
                            You need a full manual to see all adjustments
                            these 3 pages should help out
                            READ THIS PDF
                            Image Issues.pdf
                            u need to try better quality paper for that much color saturation on this small unit
                            this is not a printing press
                            go back--look at these settings >
                            change
                            back to > COPIER>ADJUST>VIFADJ>FRFS-TMP to a 1
                            and COPIER>ADJUST>VIFADJ>BKFS-TMP to a 1
                            in Service Mode.
                            Then in User Mode go to Additional Functions>Adjustment/Cleaning> and perform a Fixing Unit Cleaning.
                            FRFS-TMP Fixing temperature front side setting value
                            [When used]
                            [Adjustment method]
                            [When used]
                            [Adjustment method]
                            • mark121381
                              • Jul 2011
                              • 85
                              READ THIS PDF
                              [ATTACH]19015[/ATTACH]
                              change
                              in Service Mode.
                              [When used]
                              [Adjustment method]
                              [When used]
                              [Adjustment method]
                              Hello Sir teckat,
                              1. (u need to try better quality paper for that much color saturation on this small unit ) - as you said here, what paper type can you recommend on this type of much color saturation?
                              2. COPIER>ADJUST>VIFADJ>FRFS-TMP to a 1
                              and COPIER>ADJUST>VIFADJ>BKFS-TMP to a 1) - I change this both settings into 1, then I see some changes, when we tried to print in 1 set, the images become good but when print goes on the problem occurred again.So I suggest to my customer to do printing every set so that the machine can rest. I believe into your thoughts that this machine is not for that kind of printing press. They are printing lots of images with that much of color saturation.
                              3. SPLMAN - I checked it, all settings are 0 as per manual note in the settings.
                              Thank you for all helpful tips, I learned a lots here.
