IR2230,4570 Tray Destination
  • mramlawi
    • Jul 2011
    • 838
    Dear all ,
    i want some clues about this problem actually it happen with me today at my workshop ,i know its not a big problem ,i pressed on the common settings theres a Tray destination ,i noticed its not appearing on my machine IR 4570,also on ir 223o theres no tray destination ? i initialize that maybe cos this series is old must get the latest system software ,but on ir 4570 never happen this with me . ?is theres any thing must do to let it appear ?
    Regards ,
    Distinguished road makes you jewel in rough
    • 23009
    Re: IR2230,4570 Tray Destination
    IIRC this machine has a paper size dial in the front right of the tray (maybe front left?). Anyway, if the size is not set correctly you can get this. =^..^=
    • mramlawi
      • Jul 2011
      • 838
      iirc this machine has a paper size dial in the front right of the tray (maybe front left?). Anyway, if the size is not set correctly you can get this. =^..^=
      wierd actully ,cos i usually change the destinatin of paper ,if i want to print i go to tray destination and choose tray a or b or c now i couldnt
      • Rachid.Akli
        • Oct 2011
        • 595
        Hello,
        Are the trays displayed in copier mode ( on the LCD screen)? Can you use them (in copier mode)?
        Rachid.
        "Find a job you love and you’ll never have to work a day in your life." Nagy's father
          Set copier > option > acc > intray to a 1 and restart the copier.
          • Brian8506
            • 1665
            Tray designation is for the finisher. Do you have a finisher on the machine. It dictates which tray to send copies, faxes and prints to.
            • mramlawi
              • Jul 2011
              • 838
              Dear all ,
              i want to thank you all especially to SkyNet i make as u wrote and it work
              thanks again
              • Canon.Tech
                • Mar 2009
                • 335
                You can also use the RIGHT exit tray (remove the blacking cover cover on the top of the right door)
                To use this set COPIER<OPTION>ACC>OUT TRAY = 1
                • mramlawi
                  • Jul 2011
                  • 838
                  Thanks for the information it works with me as skynet worte ,
