iR5000/6000 finisher E540 ( Code 01)
  • bpppp
    • Aug 2025
    [Error Code] iR5000/6000 finisher E540 ( Code 01)
    1. Clean the tray home position sensor (P18) or replace it .
    2. Check the tray lift mechanism.
    3. check the finisher controller PCB
    4. Check wiring from the finisher controller PCB to the lift motor.
    5. replace lift motor (M5)
  • Gerhard
    • Oct 2009
    • 99
    Re: iR5000/6000 finisher E540 ( Code 01)
    Just a question. When you swich on the machine what happens. Does the trays try to move (find home position) or does the machine give you E 540 straight away ??
    Regards
    sigpic
    Life is a Journey enjoy the ride !!!
    • teckat
      • 16083
      E540 Error Code
      It may be necessary to perform the height sensor adjustment.
      Follow procedure below:
      • teckat
        • 16083
        A defective MS2 / MS6 can cause E540 codes. Inspect and make sure MS2 / MS6 are actuating properly. The part number for MS2 / MS6 is FF3-4021-000.
