- Clean the tray home position sensor (P18) or replace it .
- Check the tray lift mechanism.
- check the finisher controller PCB
- Check wiring from the finisher controller PCB to the lift motor.
- replace lift motor (M5)
iR5000/6000 finisher E540 ( Code 01)
[Error Code] iR5000/6000 finisher E540 ( Code 01)
Tags: None -
Re: iR5000/6000 finisher E540 ( Code 01)
A defective MS2 / MS6 can cause E540 codes. Inspect and make sure MS2 / MS6 are actuating properly. The part number for MS2 / MS6 is FF3-4021-000.**Knowledge is time consuming, exhausting and costly for a trained Tech.**Comment
