OK never had to upload data before, having to replace a bad Main Controller PCB. It ways to backup the data from the copier first. It said to use safe mode for uploading. That is the 2 & 8 / on till download shows on the display. How do I get to the Upload Data screen? Went through the SST and I do not see the upload Data button anywhere. How do you do this? Thanks
Canon SST - uploading
Re: Canon SST - uploading
Hello,
There is a detailed description of the SST in all canon documentation as far as the corresponding model uses SST for system downloading. It's under "upgrading" chapter.
Rachid."Find a job you love and you’ll never have to work a day in your life." Nagy's father -
The upload/download of SramDCON and SramRCON can be possible only in the normal mode.
-Normal mode (download mode B)
(Turn the main power ON by pressing '1+7' and select the following service mode: COPIER > FUNCTION > SYSTEM > DOWNLOAD) UPLOADING
1) Activate SST.
2) Select the model to be connected and then the information file for individual download under ('Single'), and click [Start] button after checking the network settings.
3) Click [Data upload] button>
4) Select 'SramDCON' and click [Start] button
5) Input a file name to be saved, and click [Save] button after inputting memo, if necessary.
6) Click [OK] button.
-SramRCON
-SramDCON
- In case of replacing the DC Controller PCB, upload the SramDCON, and then download it after the replacement.
SramRCON, SramDCON, and MeapBack can be downloaded only to the machine from which upload is performed.
Download Procedures
1) Activate SST.
2) Select the model to be connected and the information file for individual download ('Single'), and click [Start] button after checking the network settings.
3) Click [Data download] button.
4) Select the data to be downloaded, (SramDCON) and click [Start] button.
5) When the download is completed, click [OK] button. It returns to the previous screen.**Knowledge is time consuming, exhausting and costly for a trained Tech.**Comment
Hi,
Read the attachement. I hope it will help.
Rachid.
uploading procedure.pdf"Find a job you love and you’ll never have to work a day in your life." Nagy's fatherComment
-SramDCON/ is that a typo in book ??
NORMAL MODE: Hold down the 1&7 keys while turning on the power, hold until you see 'FIX IP' in the upper right corner of the display. (Note: In normal download mode you will see a full display also). When using normal mode you must also go into service mode under-COPIER/FUNCTION/SYSTEM/DOWNLOAD, highlight DOWNLOAD and select OK to put the machine into standby for receiving data from your computer. You can use normal mode to flash the following software and firmware:
- Formatting hard drive individual partitions- DosDev, FSTDev, DosDev2, FSTPDev, DosDev3, PDLDev, DosDev4, DosDev5.
- System, Language, RUI, Boot (individual partitions), G3fax, Dcon, Rcon.
- Upload backup data- SramImg, SramDcon, SramRcon.
- Download backup data- SramImg, SramDcon, SramRcon.
Last edited by teckat; 10-30-2012, 09:17 PM.**Knowledge is time consuming, exhausting and costly for a trained Tech.**Comment
I see he has an old version of the SST v3.35, maybe the upload option isn't on that version!?Comment
Printer first needs to be in NORMAL MODE / 1 & 7 & not in usual Safe Mode( 2 & 8)
then launch the SST
Data files are now shown under "SINGLE" when in NORMAL MODE 1 & 7
needs to be in NORMAL MODE > then select connect>then select model > then while selecting SINGLE under the model in SST/ U should then see the SramDcon file data file**Knowledge is time consuming, exhausting and costly for a trained Tech.**Comment
Techat, finally got to the screen and uploaded the files, thank you. I am going to replace the Main controller PCB, never done this and am using caution. Someone said it needs to me mated to the machine? Is there anything I need to know before I procede, do not want to do something wrong and lock the machine up. ThanksComment
small SHEET, PROTECTIVE on back/ new pcb should have one on
if not/u may be able to remove & re-attach
FB4-1494-000
read------Main Controller.pdf
after replacing the main controller PCB, be sure to transfer the following components from the old to
new PCB.
[1] Boot ROM
[2] Hard disk
[3] Image memory (SDRAM)
[4] Counter memory PCB
then re-laod files**Knowledge is time consuming, exhausting and costly for a trained Tech.**Comment
