las copias y las impresiones pasan sin problemas pero me esta indicando este mensaje; como puedo borrar este mensaje o a que se debe imagino que no va a compaginar?IMG_0250.jpg
FINISHER CANNOT BE USED in ir7095
Re: FINISHER CANNOT BE USED in ir7095
Hello,
"Functions limited" is displayed because you have a finisher issue. In service mode>copier>display>error, you can find the finisher error code. Once solved, open the common settings menu, look for the"functions limited" and put it on "no".
Rachid."Find a job you love and you’ll never have to work a day in your life." Nagy's father -
Common Settings-*is the default setting
Limited Functions Mode= items will appear only when the appropriate optional equipment is attached.
Finisher Tray A/B: ON/OFF*1
Finisher Saddle Stitcher Unit: ON/OFF*1
Finisher Inserter: ON/OFF*1
Folding Unit: ON/OFF*1
Puncher Unit: ON/OFF*1
Stacker: ON/OFF*1
turn all OFF**Knowledge is time consuming, exhausting and costly for a trained Tech.**Comment
Stacker: ON/OFF*1
turn all OFFComment
Encontramos unos pedasos de metal al parecer son unos ganchos metalicos que estaban atorados entre las bandejasComment
