Canon i-sensys MF8330Cdn ID / PW?
  • Tompi
    • Aug 2025
    Hi! How can I restore the default ID / PW or to set up new ones for Canon i-sensys MF8330Cdn? I really have no idea what those should be.. Thanks for your help!
  • teckat
    • 16083
    Re: Canon i-sensys MF8330Cdn ID / PW?
    System Settings
    Initialize System Settings
    Resets the following system settings to the default values.
    System Manager Information
    Device Information
    Dept. ID Management
    Network Settings
    Communications Settings
    Forwarding Settings
    Store/Print When Forwarding
    Remote UI On/Off
    Restrict Sending
    Display Job History
    USB Device On/Off
    Memory Media Storage On/Off
    Select PDL (Plug-n-Play)
    Initialize All
    if needed
    • Tompi
      Originally posted by teckat
      System Settings
      Device Information
      Dept. ID Management
      Network Settings
      Forwarding Settings
      Remote UI On/Off
      Restrict Sending
      Display Job History
      USB Device On/Off
      Initialize All
      if needed
      Hi, sorry for late response. This printer is at my parents' house and I couldn't get here until now..
      So, I didn't quite understand what you meant with your instuctions. When I access the main setup -> system settings, printer asks for the id and pw but I don't know them! How can I proceed with this problem?
      Thanks for your answer.
      • Tompi
        Here is 3 photos of the printer screen. Language is finnish but I'll translate them for you
        1. Start screen
        2. Main setup at "System settings"
        3. Printer asks for the ID / PIN. This is the last stage I can access.
        • teckat
          • 16083
          Try to get in service mode
          /to CLEAR
          think it's MENU key then # Key
          then # SSSW
          on display menu-Data Initialization Mode (CLEAR)
          # CLEAR
          Registration/settings of user data and service data are initialized with CLEAR ALL, and go back to factory default
          • Tompi
            /to CLEAR
            then # SSSW
            # CLEAR
            Nothing happens when I try to press # button after pressing menu key. Printer just beebs after pressing # or other buttons. I uploaded a video to Youtube so you can see what I mean. Language in the menus is finnish...
            youtu.be/uch-oPsUAJE
            I appreaciate your help!
            • teckat
              • 16083
              poor link- u need to use the insert video icon on menu/see example in pic
