scaner cu40
  • alexctx
    • Dec 2010
    • 157
    scaner cu40
    scanner makes noise.
    and nonuniform compensation.
    The calibration was discarded.
    help.
    known cases
    jpg1 A1. horizontal.
    pdf 2 A0. vertical.
    2.pdf
    video
    scaner ci40 - YouTube
  • teckat
    • 16083
    Re: scaner cu40
    help.
    known cases
    pdf 2 A0. vertical.
    [ATTACH]18247[/ATTACH]
    [ATTACH]18248[/ATTACH]
    video
    get a pair of these>>
    • V-P
      • Apr 2011
      • 679
      Re: scaner cu40
      for the noise thing : open up the scanner and clean the rubber rollers and grease the mechanical gears.
      for the displacement: run stiching program (maybe another name it is used now)
      But for sure there are some wizards in the software that comes with the scanner.
      As far as I remember from Colortrac cX40 series (which pretty much is what you have): you need to print out a test sheet & than scan it under the stiching program
      and than +- the values until you are satisfied.
      • alexctx
        • Dec 2010
        • 157
        Re: scaner ci40
        if it is used for. when you have displacement. uniform. but look at the evidence is mixed.
        at first. no. then yes. displacement and sometimes just
        SCANER.pdf
        • V-P
          • Apr 2011
          • 679
          Re: scaner cu40
          swap flat cables between the 5 ciss to see if the "problem" moves.
          than you will know
          • alexctx
            • Dec 2010
            • 157
            Re: scaner ci40
            I will, after I tell the resustados ok thanks
            • V-P
              • Apr 2011
              • 679
              Re: scaner cu40
              resustados = garantidos (lol)
              just practicing my peruano
