E161-403F
  • skazic
    • Nov 2009
    • 25
    [Error Code] E161-403F
    Regards,
    I have iPF9100 that has this error
    Replaced the head, flex cable, PCB cariage, head PCB and main PCB
    printer was working about 2 months and appeared again the same error
    Do you have any ideas
    Thanx
  • zoraldinho
    teacher-guide-expert-guru
    • Mar 2008
    • 5018
    Re: E161-403F
    Firmware upgrade? OEM ink?
    Subject:
    Error record of Head Temperature Rise error
    Detail:
    When the Temperature Rise error (E161-403E or 403F) occurs, three records are recorded per error on the error
    record of Print.Inf. Therefore, the frequency of occurence should be counted as once for three records. A countermeasure
    will be taken so that one record is recorded per error.
    • skazic
      • Nov 2009
      • 25
      Re: E161-403F
      Use genuine ink and the last version of fw is on printer.
      • V-P
        • Apr 2011
        • 679
        Re: E161-403F
        Actually that one in old machines is a BIATCH !
        I have had it in 2 occasions.
        First (iPF8000) customer dropped out (it was not financially worthy).
        On the second case we replaced "at the same time"
        Mainboard + carriage system + 2PF03
        Than it worked...
        Good Luck !
