Canon MX330 Error
  • ldfrepairs
    • Oct 2012
    • 148
    Canon MX330 Error
    Printer will not power off and alarm lights stays on. Any suggestion on what the cause may be?
    drugstore-onlinecatalog.com
    • 16083
    Re: Canon MX330 Error
    what is the error message ?
    Press the "ON/OFF" button to power down the machine, then unplug the cord from the wall outlet or surge protector. Wait for about one minute. Plug the printer back in to its power source and turn it back on.
    or--------------------------
    pull the plug> leave out 20min.> plug back in
    • ldfrepairs
      • Oct 2012
      • 148
      As the power is plugged in the alarm light is on. I tried pressing the power button to power off but nothing happens
        • 16083
        what were u doing before lamp came on ??
        Error Message ??????????????????????????
        can u see the LCD Screen
        Alarm lamp
        Lights or flashes orange when an error, such as paper-out or ink-out, occurs.
        Disconnecting the power plug
        When disconnecting the power plug after turning off the power, be sure to confirm that the ON button
        is not lit. If the power plug is disconnected from the wall outlet while the ON button is lit or flashing, the
        machine may become unable to print properly since the Print Head is not protected.
        If the power plug is disconnected, the date/time settings as well as all documents stored in memory
        will be lost. Send an unsent fax or print a necessary document before the power plug is
        disconnected.
