canon ir2016 Jamming PRoblem
  • mramlawi
    • Jul 2011
    • 838
    [Jamming] canon ir2016 Jamming PRoblem
    Dear all ,
    i have Canon Ir2016 with 1 drawer ,i bring the machine to my work shop and i dessasamable it ,to clean it from Toner ,i dissassamble the feed Unit for the Cassette it was working fine after i dessamble it the machine start gives me incorrect paper size ,after too many dessambles the massage disapperd and now it jamming when exit the drawer , what i noticed that the paper when i press to copy the paper from the cassette exit and then enter back again to the drawer so i think theres somthing wrong in this ,is theres any specific adjust for the solonied or the clutch i also clean the clutch of the unit but same problem . reply with some pic if u please .(i dessamble all the gears and greased it and clean it then i turn it back).
    thanks
    Distinguished road makes you jewel in rough
  • zoraldinho
    teacher-guide-expert-guru
    • Mar 2008
    • 5015
    Re: canon ir2016 Jamming PRoblem
    Never do this (i dessamble all the gears and greased it and clean it then i turn it back) if you have worked machine.
    Check duplex solenoid and flapper.
    • Rachid.Akli
      • Oct 2011
      • 595
      Hi to all
      Verify or replace the clutch: FK2-1068-000.
      Rachid.
      "Find a job you love and you’ll never have to work a day in your life." Nagy's father
      • mramlawi
        • Jul 2011
        • 838
        the machine without duplex man ,which flapper u mean ???
        • zoraldinho
          • Mar 2008
          • 5015
          Sorry.Im in other post in my mind.How do you mean "enter back again to the drawer"?
          • kannuki2
            • Feb 2012
            • 398
            here's the picture
            • mramlawi
              • Jul 2011
              • 838
              its ok ,thanks for all first , i mean its my first time i observe how the paper process work ,i saw the paper when i opened the left cover and pressed start to copy the paper exit the cassette a while and then back to the cassette then it comes up to enter the registration roller .what happened with me is the paper jammed on befor the regestriation ,i cleaned all the clutchs ,and as i said before it was working fine but when i dissasamble the unit and greased the gears its jammed and gave incorrect paper size and jammed
              regards to all again
