toner erased in IR 2520
  • mido
    • Nov 2011
    • 177
    Hi all,
    I have a problem in IR 2520, the toner on the copy paper didn't fixed, erased by my finger,
    the counter of the machine is 12k copies.
    I did the following:
    * I changed the temperature adjustment of the heater by service mode 62, the default is 7 , I changed it up and down but it still erased.
    * I changed the old toner powder from development unit and install new one, but it still erased,
    * I changed the fixing film unit to new one, but also still erased,
    I need your advice about this problem.
    thanks in advanced
  • zoraldinho
    teacher-guide-expert-guru
    • Mar 2008
    • 5015
    Re: toner erased in IR 2520
    Three things you can do in your case:
    Use OEM toner
    Install latest firmware
    Change paper
    Check settings if you have different tipe of paper.
    • mido
      • Nov 2011
      • 177
      Use OEM toner
      Change paper
      Dear my friend
      thank you for your reply,
      I use OEM toner and changed the type of paper, but I don't instal latest firmware because I don't have it,
      if you have a firmware can you send it. this is my email: lehusein@mccc-ltd.com
      Regards
      • Brian8506
        • 1665
        Sounds like there's no pressure on the fuser. Check that 1st.
        • canonbundy
          • Jun 2012
          • 607
          Originally posted by mido
          Hi all,
          thanks in advanced
          You say that you changed the OLD toner - was it OEM? - if not you will need to completely empty & vacout the Developing Unit & reinstall the NEW Toner.
          • mido
            • Nov 2011
            • 177
            my friend,
            I didn't hear any sound, everything is very normal, also I jammed a paper in the heater unit and check if no tension exist between upper and lower, but it was equal in both sides front and rear side are equal.
            • mido
              • Nov 2011
              • 177
              My friend,
              the old toner was OEM, and I completely empty the developing unit, then reinstall new toner
              Regards
              • Brian8506
                • 1665
                It still sounds like lack of fuser pressure not uneven pressure to me. Does the whole page erase if you wipe it?
                my friend,
                • mido
                  • Nov 2011
                  • 177
                  yes the whole page erased
                  • Brian8506
                    • 1665
                    You need to check and see if pressure is applied when the door closes. There should a lever or handle that the door contacts when you close it to put pressure on the upper film with the pressure roller.
                    • arielcanon
                      • Mar 2012
                      • 106
                      You have changed toner to OEM and Fixing Unit. Try to reset to factory setting, Clear > All, from service mode. If you have another good machine with the same type, try to borrow it's fixing unit.
                      Learning never ends..
                      Never give up, where there is a wheel there is a way..
                      • Brian8506
                        • 1665
                        Poster said he changed the film unit. You need to check pressure roller, pressure cams and anything that has to do with applying pressure in the fixing assembly.
                        Hi all,
                        thanks in advanced
                        • ericang
                          • Dec 2010
                          • 39
                          1st: you have to be a real copier tech..
                          2nd: have a 2nd working machine n try to replace those related part one at a time
                          (part: developing unit, fixing unit, right door)
                          as what i experienced the most of this problem usually come from FAKE OEM toner n fixing tension issue
                          and try to check on the fixing unit is working correctly when the door open n close....
