Canon iR2200if need help configuring scan from network!
  • dmdougie
    • Aug 2025
    Hi all,
    Scanning the net for a solution to this, most hits seem to lead me back to this forum so thought I'd ask here as it seems pretty full of experts!
    We have the above MFD in our office and it works fine for printing through the network. However, I can't figure out how to set it up for network scanning. It has an IP assigned through DHCP, though it doesn't show up in my Network area via Control Panel under Windows 7. I can't see anywhere where I can configure the device for scanning through the network.
    The Remote UI, which was working up until 5 minutes ago and is now timing out, was showing that the Scan status was sleep. Any idea how I can wake it up?! Is that likely done through the Remote UI or, seeing as I am locked out of there right now, can I do something on the device itself?
    Any help is much appreciated, please let me know if I have been to vague and I'll do my best to get the required information.
    TIA
    Doug
  • teckat
    • 16083
    Re: Canon iR2200if need help configuring scan from network!
    Originally posted by dmdougie
    Hi all,
    TIA
    Doug
    Download----------Network Scan Gear
    Network ScanGear v2.30
    then u---------
    need to be ONLINE for Scan(Additional Functions) → [System Settings] → [Auto Offline]
    Select [On]
    • dmdougie
      Thanks for the reply but I cant find the 'Auto' section under system settings. Is there a special key combo I have to press to see an additional menu, I read somewhere else here that you may have to do that...
      • teckat
        • 16083
        did u download ScanGear & read the manual ??
        When the Network Scan function is not attached, [Auto Offline] is not displayed.
        [Auto Offline] is only displayed when the Network Scan function is enabled.
