Is the IR7105 capable of twain scanning using Scan Gear or can it twain scan?
Canon IR7105 twain scanning
Re: Canon IR7105 twain scanning
Network ScanGear v2.21
http://www.irfanview.com/
Network ScanGear is a 32-bit TWAIN-compliant scanner driver that allows computers on a
network to use a Canon iR series digital copier as a scanner.
It consists of the following software.
ScanGear Tool
This software is installed together with the Network ScanGear driver, and enables the
user to select the device name of the scanner on the network to be used for scanning with
the Network ScanGear driver. No scanner is selected during Network ScanGear
installation, so you must start the ScanGear Tool and select a scanner before use.
This is a scanner driver that can be accessed from TWAIN-compliant applications. This
driver is then used when scanning.**Knowledge is time consuming, exhausting and costly for a trained Tech.**
