Canon IR7105 twain scanning
  • skibum
    Independent Service Tech
    • 234
    Is the IR7105 capable of twain scanning using Scan Gear or can it twain scan?
    • 16083
    Re: Canon IR7105 twain scanning
    Network ScanGear V2.30 for Windows 2000/XP/Server 2003/Vista/Server 2008/Windows 7 (32bit)
    Network ScanGear v2.21
    http://www.irfanview.com/
    Network ScanGear is a 32-bit TWAIN-compliant scanner driver that allows computers on a
    network to use a Canon iR series digital copier as a scanner.
    It consists of the following software.
    ScanGear Tool
    This software is installed together with the Network ScanGear driver, and enables the
    user to select the device name of the scanner on the network to be used for scanning with
    the Network ScanGear driver. No scanner is selected during Network ScanGear
    installation, so you must start the ScanGear Tool and select a scanner before use.
    This is a scanner driver that can be accessed from TWAIN-compliant applications. This
    driver is then used when scanning.
    • V-P
      • Apr 2011
      • 679
      Everyday smth new...
      I didn't know IrfanView supports Canon Netgear
