i have a V2 that thru a E5fa6 code . I replaced the saddle control board no fix. found out that i am not getting 24 volts from fuse/relay board in back. Relay never clicks on to apply 24v. 24V is on the relay /fuse board from power supply and i can not find any bad fuses. 24-30-and 5v are present. All the lights on the control board are lighting but in the version display it read 1.3 and i know i had it at 22.0 . If i hold relay in during power up i get random E533 and E566 codes. I am leaning towards the main finisher controller any ideas out there ?
Saddle stitch Finisher v2
Tags: None
Re: Saddle stitch Finisher v2
Hello,
Do you confirm the E5FA6 error code? It doesn't exist in the documentation.
Before replacing the finisher controller, verify the MSW switches and their corresponding open/close mechanisms. They usually controlle relays.
Rachid."Find a job you love and you’ll never have to work a day in your life." Nagy's father -
Right sorry code is E5FA-8000Comment
