Re: Saddle stitch Finisher v2
Right sorry code is E5FA-8000
Hello,
Do you confirm the E5FA6 error code? It doesn't exist in the documentation.
Before replacing the finisher controller, verify the MSW switches and their corresponding open/close mechanisms. They usually controlle relays.
Rachid.Leave a comment:
i have a V2 that thru a E5fa6 code . I replaced the saddle control board no fix. found out that i am not getting 24 volts from fuse/relay board in back. Relay never clicks on to apply 24v. 24V is on the relay /fuse board from power supply and i can not find any bad fuses. 24-30-and 5v are present. All the lights on the control board are lighting but in the version display it read 1.3 and i know i had it at 22.0 . If i hold relay in during power up i get random E533 and E566 codes. I am leaning towards the main finisher controller any ideas out there ?Tags: None
