Touch Screen Imagepress C1
  • idprint
    [Misc] Touch Screen Imagepress C1
    Had problems with the touchscreen on a Imagepress C1. Don't laugh, I have 2 I have to service!
    Looking through this forum I came across this entry http://www.copytechnet.com/forums/ca...ms-oh-joy.html
    Similar problem as mine. Problem with the possible answer, to get into MN-CON in service mode, you need a working screen!! Especially as in my example, you could not get to the top part of the screen to get to the MN-CON section!
    Another post here with similar issues http://www.copytechnet.com/forums/ca...epress-c1.html
    BUT the solution was to purchase the following "If you have old control panel unit FL2-2616,replace with new one FL3-1063 Also need to replace Inverter PCB Assembly with new one FK2-7408"
    Please note as an addendum, Part FL3-1063 comes with a FK2-7408 already, so PLEASE CHECK before you order as in Australia as it is an additional (wasted)$60. The part FL3-1063 is $600AUD.
    BUT this did not fix the problem. An expensive mistake. Check to see the actual touchscreen is the fault - Part FK2-1645. This may affect the following machines: imagepress C6000VP, C7000VP, Imagerunner 7086 imagerunner 7095, imagerunner 7105 and the Advance C9065 Pro and Advance C9075 Pro. This is because the part according to Canon FK2-1645-000 Cover / Panel, Genuine (E2489)
    is compatible with those machines. Cleaning behind the panel very carefully seemed to fix the problem for awhile but only the top was un-responsive and because you could not get into service mode to run a calibration, this option was useless.
    Question: Is there a way to clear an error message without using the touch panel, ie via web interface?
  • zoraldinho
    teacher-guide-expert-guru
    • Mar 2008
    • 5015
    Re: Touch Screen Imagepress C1
    This is the way.......http://www.copytechnet.com/forums/ca...ation-kit.html
    • spectraindo
      • May 2008
      • 313
      Touch Screen IP C1 = $100.00 , email me spectra@indo.net.id.
      • fabiano jacob
        Originally posted by zoraldinho
        Helo,
        Do you have this software remote operator kit?
        Thanks;
        Fabiano.
        • idprint
          Originally posted by fabiano jacob
          Helo,
          Thanks;
          Fabiano.
          No i dont. I am waiting on a replacement part Part FK2-1645, to see if it fixes the problem first. Its cheaper than the remote operating kit. I'm not giving any more good money at the C1
          • zoraldinho
            • Mar 2008
            • 5015
            remote operating kit is free software for Canon certified tech. and yes i have it.
