IR2520 add paper
  • Bole
    • Dec 2012
    • 34
    IR2520 add paper
    Hi
    I have problem with IR2520 because they show ''add paper'' even if the paper is full in cassete. When I take out the paper cassete and push it back and press 3sec. to end after that the copier detect the correct format and level of paper.
    I think this is not mechanical error but Im not shure?
    Do you have any other idea?
    Thank you
    Bole
  • teckat
    • 16083
    Re: IR2520 add paper
    Originally posted by Bole
    Hi
    Thank you
    Bole
    make sure your cassette latch is locking properly to printer body/ remove covers to inspect & adjust
    remove cassettes look inside to make sure nothing is blocking tray switches (torn paper)
    • youCan
      Hi,
      you need to remove the paper behind the cassette.
      Possibly the cassette must mechanically adjusted, so that sensors can be pressed to the paper size.
      • COPIERTEC ASSOCIATES
        • Aug 2011
        • 279
        I have come across over 10 ten machines in the field with this problem.Many times i have re-opened the machine to make sure the cassette latches lock properly,but the machines will detect the paper for
        a short while and go back to the same scenario,despite some times putting some supportive device to keep the cassette in place.On closer observation,the problem could be a factory default because in all this attempts sometimes i have changed sensors to no success.It is a topic worth discussing.
