Canon IR C 5180 Error Code 000007-0211
  • Doug James
    • Jan 2012
    • 935
    [Error Code] Canon IR C 5180 Error Code 000007-0211
    I am having trouble understanding this code. Assuming this is in the fuser area.Can't find much on this...
    Anyone have the exact meaning of this code...
  • pontiac
    • 420
    Re: Canon IR C 5180 Error Code 000007-0211
    Fuser belt problem, there isn't much you can do with these fusers, but replace to fix problem. If im correct Canon sells these refurbished for $800.00.
      • 16083
      sell only to authorized dealers
        • 16083
        READ PDF/--5185_007 Checks.pdf
        Disassembling and Reassembling_Fixing Unit_TP07-168.pdf
        this other pdf shows/Disassembling and Reassembling Fix Unit> and shows parts> these parts usually do not fix all issues for E007>it's like Trial & Error that does not pay in long run-
        TIME is MONEY in this field
        but as stated> your best bet is to replace unit
        • aAandy
          • Apr 2012
          • 370
          i know this is an old thread, but i've had two machines with this problem recently & thought i'd share my remedy for future reference
          from what i understand this code actually refers to the fuser not moving at the same speed as the machine, though this actual code was not listed in the service manual (iRC5180/5180i/4580/4580i/4080/4080i/3880 CLC5151/4040/4080i)
          on both machines, i found there are two worn straight-cut hardened gears deep inside, on the copier front-side of the fuser unit, between the upper & lower belt assemblies,, which drive the lower belt assembly from the upper belt shaft (you will not see these gears in any parts diagram)
          i dismantled the entire fuser unit (an hour +), removed both belt assemblies, removed & reversed the 2 worn gears applying liberal high temp lithium grease, then reassembled & refitted the fuser - this got the machine up and running in around 2.5 hrs to the great relief of my client
          seeing everything else in these fusers looked kinda like new (shiny unwrinkled belts), i had 4 gears cut & hardened by a local engineering firm (using a gear i removed from an old fuser unit) which cost me $90.00 each & then went through the entire process again to fit the new gears - heck of alot cheaper than 2 new fuser units
          NOTE - this is not a job for your standard copier tech, i have 30+ yrs experience (mechanical, electrical & electronics to component level), 18 yrs in business for myself & i also subcontract to top end manufacturers when their guys run into problems - that being said, a GOOD tech,, with patience and great care, can do this job and have the machine up and running again in approx 3 hrs
            • 16083
            Good Information
            Now Post the pictures & exact location of these mystery gearsI have worked on hundreds of these units/ also once had to maintain a major account that had 130 in one building.
            The reason we don't fuss with these units is because in a fast paced high end customers location> u don't normally have the time and space to break down this unit to do a visual inspect on site--
            another reason is there are small gears on side assembly's that have their teeth edges broken (some not visible until removal).
            U also have the cases of a upper torn belt - or fried sensor surfaces-
            we keep these units in stock for a same day delivery response repair/ pop out>pop it
            • DAG COPIERS & COMPUTERS
              • Oct 2010
              • 860
              Both of you (aAandy & teckat), have valid points. Talk of workshop versus field repair, as well as time factor. Then there's the type of client as well as the money factor.
              • Doug James
                • Jan 2012
                • 935
                Thanks so much for this... Good stuff
                  • 16083
                  Please Post the pictures & exact location of these mystery gears
                  plus pics of your cut stamped replacements
                  • w0179651
                    • Jul 2015
                    • 24
                    I have fixed this error on the Canon iR C4080.
                    Error Code 000007-0211 means the lower fuser belt is not centered and to the left.
                    Error Code 000007-0201 means the lower fuser belt is not centered and to the right.
                    7-0211-0201.pdf
                      • 16083
                      [ATTACH=CONFIG]29970[/ATTACH]
                      [ATTACH]29971[/ATTACH]
                      Gold-award.jpgyou win~~~~~~~~~~~~~~
                      Thanks for the information/ I have done that adj a few times myself / just to get the hell out of a customers face
                      only to later discover broken/missing teeth on those crappy gearson return calls
                      Service Company was smart enough to keep large stock of refurb units on hand ------10 min work & all are happy until next breakdown
