Canon np 3030 disable code ID HELP
  • tecnomarco
    • Jul 2011
    • 213
    Greetings to all, I have an old Canon NP 3030 has enabled the code user (ID), I do not know how to disable someone can help me ...
  • irtek
    • Jun 2009
    • 110
    Re: Canon np 3030 disable code ID HELP
    Going from memory here so I hope I get it right. Press in order *-ID-Auto zoom-* that should get you in the ID setup. I think then you just have to delete all user codes and that will disable the ID mode. The procedure is in the Operators manual if you have one.
      • 22997
      Press *, ID, Auto Zoom, *, to enter ID mode. Press 2, then 1, to see existing registered ID's. To register your own ID choose ID # registration : 1, then enter your new four digit #, then *.
      Sounds right irtek. =^..^=
      • tecnomarco
        • Jul 2011
        • 213
        thank for your suggestion
