Replace Toner container C9065
  • dungtn
    • Oct 2012
    • 24
    Hi!
    How to replace Toner container not empty from Canon C9065?
    Thanks for your help!
  • vigour
    • Aug 2010
    • 1038
    Re: Replace Toner container C9065
    http://www.copytechnet.com/forums/ca...c9075-pro.html
    • dungtn
      • Oct 2012
      • 24
      I want replace toner container, not waste toner bottle!
      thanks!
      • Cabo
        • Aug 2012
        • 41
        I think the procedure is the same as the IRC ADV 50xx:
        Enter service mode *2&8* (level 1)
        *2 (level 2)
        Copier>option>displaysw>level2>tcrgsw>enter 1
        Get out SM
        *Adjusment&maintenance>replace toner>chose toner>ok
        After replacing the toner return no 1 on 0
        Sorry for my English
        • vigour
          • Aug 2010
          • 1038
          No problem with your English pal.
          That procedure was correct.
          • dungtn
            • Oct 2012
            • 24
            *2 (level 2)
            Get out SM
            I've do it succesfull.
            • Zela
              • Mar 2014
              • 25
              hello
              I have a similar problem.
              I disassembled i gear color hooper.
              While it goes and then turn Replace Toner message.
              Cogwheels crack what I had been altered but now they are alright.
              Sensors are clean, gears revolve. Firmware last.
              I do not know what it can do.
              • vigour
                • Aug 2010
                • 1038
                So you followed all the instructions and took the hoppers out.
                You replaced the gear.
                Did you put he toner tubes back in?
                If not, tnen open the door by service mode or use the white crank screwed on the yellow hopper to open the door.
                Insert toner tubes and you should be good to go.
                • Zela
                  • Mar 2014
                  • 25
                  After disassembling the previous January it by itself after a week became operational.
                  I do not know where she could be a mistake.
