Canon IR3235 grinding noise--see explanation
  • axyun
    • Aug 2007
    • 1323
    When machine is warming up or in cycle it makes a grinding sound every half second. Someone else was there and told customer he needed fuser unit. Ran machine with right door open and transfer unit closed and no noise.
    Removed drum unit and dv unit and gears appear okay and both turn freely manually. I removed the gear behind the little cover on upper right inner frame at 2nd upper delivery because it mated with gear on upper right side door. I did that because noise only happened with door closed but still had grinding sound. I am thinking it may be a broken tooth on a drive gear but did not see one. Any help is very much appreciated as I am far from an expert on machine. I will post results. Frank/ActionPhotocopy
    PS...Also the machine jams a few inches below fuser
  • zoraldinho
    teacher-guide-expert-guru
    • Mar 2008
    • 5015
    Re: Canon IR3235 grinding noise--see explanation
    Someone else was Canon technician i suppose.Remove fixing unit end inspect gears.In any case you need spare part so call authorized Canon dealer.
    • canonbundy
      • Jun 2012
      • 607
      Could be that someone has opened the R/H door too far and bent the hinge, close the door and check (by pushing bottom right corner of door) if there is any play and send a print through while pushing the door.
      • Brian8506
        • 1665
        Also when you run it with the door open, the pressure on the fuser is off unless you put it back on with the white slide lever. Sounds like a fuser problem.
        • northernlife
          • Sep 2011
          • 847
          Gear that drives the fuser. Brown gear in the fixing drive assembly will strip out if the fuser is seized or difficult to turn. Replace just that brown gear and the drive on the fixing assembly itself and off you go.
          • axyun
            • Aug 2007
            • 1323
            Thanks for the great responses guys. I understand now that when the door is close there is a pressure arm on door which applies pressure to pressure roller and fixing film. So leaving door open to watch fuser wouldn't give me the same action as when door is closed. The fuser was turning though without any noise so it may not be gear but more pressure form walking fixing film when pressure arm is engaged. I will post results when call is complete. Have a nice weekend . Frank
            • Brian8506
              • 1665
              You can push that white lever in to apply pressure and test with door open
              • axyun
                • Aug 2007
                • 1323
                Thanks Brian. That's what happens when you service a lot of different equipment because business is slow but accumulating more knowledge on different makes and models is very rewarding. Have a nice weekend. Frank
                • spectraindo
                  • May 2008
                  • 313
                  Check the Hopper, sometimes the Toner Bottle makes noise when rotating.
                  Operate the machine with the front door open to see the Bottle.
                  • axyun
                    • Aug 2007
                    • 1323
                    Thanks Spectraindo. I don't think it's the toner hopper because I ran machine with right side door open and then there was no noise. If it was hopper then it would still make noise. Have a good weekend. Frank
                    • Simons
                      • Jun 2008
                      • 490
                      Can you capture a video of it and upload to utube. The sound should be there. I find the sounds when others FAIL.
                      • axyun
                        • Aug 2007
                        • 1323
                        Thanks Mike. I am practically convinced that it is the fusing unit as there is no noise when right side door is open but when door is closed the pressure arm applies pressure to fuser and probably the fixing film "walked" and the noise is coming with the additional pressure. I will check it out further early next week. Frank
                        • canonbundy
                          • Jun 2012
                          • 607
                          The above is my original Post to this problem you have and I still say the bottom R/H side of the Right Door is not closing properly, the Registration Roller Gear is driven when the door is closed and if the hinge is bent it will NOT mesh correctly and will give a grinding noise also the paper will NOT reach the Fuser.
                          • axyun
                            • Aug 2007
                            • 1323
                            Hi Cliff. Thanks for staying with me on this one. I will check out the door when I go back there on Monday or Tuesday. Are you saying that if the door is open and I cheat the doorswitch that the registration drive gear will run smoothly with no noise but if the door hinge is bent and or the door is not closing in correct alignment that something on the door will interfere with the registration drive gear? I will push in bottom right side of door while running to see if there is a difference. GOODAY(sorry.. had to say it) . Frank
                            • canonbundy
                              • Jun 2012
                              • 607
                              Hey you're catching on Frank, however I made a small boo boo when I last Posted -it should be Transfer Roller not Rego Roller ( had a few crissy drinks) but yes the same idea, had it a few times on the different models that use the R/H door system, usually cust gets cranky with a jam, opens door and it bounces back while they try to remove paper, then they really get shitty and push it open - gotta say I haven't experienced any gear meshing noises from Fusers, plenty of other issues though.
                              Ummm it's G'DAY.
