Canon ir2200 e-000677-8502
  • sweet.persona
    Engineer
    • Nov 2009
    • 414
    [Error Code] Canon ir2200 e-000677-8502
    Hi to all
    i have replaced an old hdd by a new one (HHD ir3300) in CANON IR2200, but it desplays E-000677-8502
    how can i resolve this problem??and does the ir3300's hdd software work with ir2200?
    Note: The new HDD have network sys installed on it,but there's no Network sys slot in the machine
    Thanks in advance.
    A GREAT PLACE TO WORK - A GREAT PLACE TO GROW!
    DAMENE ABDEL AZIZ
    DJELFA
  • zoraldinho
    teacher-guide-expert-guru
    • Mar 2008
    • 5015
    Re: Canon ir2200 e-000677-8502
    E677 is wrong combination issue.Use SST and appropriate firmware.
    • teckat
      • 16083
      Originally posted by sweet.persona
      Hi to all
      Thanks in advance.
      E677 = PDL board mounting error
      E677-0001 error indicates that the Main Controller firmware and the Boot-ROM are incompatible (ex: Boot-ROM is at copier level and the system software is at network level, or vice versa). Either install the correct Boot-ROM chip or flash the MN-cont with the correct version of firmware.
      check BOOT ROM
      check print board used
      A fault occurs it the combination between any of the printer boards (accessories) and the main controller PCB.
      Main cause
      --Any of the printer boards (accessories) is faulty.
      The main controller PCB is faulty.
      Action
      1. Connector
      Is the printer board (accessory) connected correctly?
      NO: Correct the connection.
      2. Printer board, Main controller PCB
      Try replacing the printer board. Is the problem corrected?
      YES: End.
      NO: Replace the main controller PCB.
      in other words---------what options pcb's are installed
