canon
  • nih
    • Aug 2012
    • 46
    [Error Code] canon
    Hi guys good morning i have this machine by mark canon imageclass mf 5950DW. that is giving this error code E100 after that it will change to E733-0000. please some hep will be grateful.
    thank for your consent.
  • zoraldinho
    teacher-guide-expert-guru
    • Mar 2008
    • 5017
    Re: canon
    Probably connection issue on controller board.Check connectors and ribbon.You dont have that luck to get two different errors at the same time.
    • hareesh
      Re: canon
      E733 error is due to communication failure between d-con and m-con pls check the connectors between d-con and m-con if the problem persists try to change d-con
      • teckat
        • 16083
        Re: canon
        I would check the outlet for correct power output/ do u know how to check for proper voltages
        what is your room enviorment
        E100=
        BD detection PCB failure maybe laser scanner fault
        condensation on the BD sensor could cause problems associated with E100
        E733=Erroneous communication between controller and printer-
        - Check the connectors of the DC controller PCB and image processor PCB for normal connection.
        - Check the power supply of the printer (Check whether initialization is performed at start-up).
